Tatraportal.sk and Tatraportal.com forum
Forum about Tatra vehicles
It is currently Thu, 25 May 2017 11:29
Post new topic Reply to topic  [ 1 post ]
Author Message
 Post subject: Parts required for 603 in Australia
PostPosted: Wed, 16 Apr 2008 20:44
Offline
Discussion newbie
Hi All. I have a 1963 Tatra 603 in Australia and am presently rebuilding the mechanicals. Front and rear suspension are being rebuilt at the moment. I had to make a new pair of trailing arms for the rear due to the original ones being badly rusted, and found a pair of 4WD shock absorbers with the correct specification. The front shocks are being rebuilt and I had a mould made up to reproduce the rubber mounting for the top bearing. Wheel cylinders have also been stainless steel sleeved, and new steel and flexible brake lines fitted. I am however looking for a few parts which I have been unable to find or reproduce. These are:
Front outer tie rod ends. I believe a VW Transporter van use something similar, but VW Australia needs a part number. Anyone know ?
I also need two brake drums for the front, although I presume that front and rear are the same.
I also need the rubber boots that cover the tie rod where it exits the body.
If anyone can help or point me in the right direction, please send me a personal message.
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
